Leuchte 0 BLK VL B36 - Indicator front left (headlight)
Leuchte 35 LED warn blink taster c48 - LED blinkers
Leuchte 10 shutter LB23 - shutter height for lights
Leuchte 10 shutter RB23 - shutter height for lights
Leuchte 12NL LB45 - fog light
Leuchte 13NL RB5 - fog light
Leuchte 16BLK SLB35BLK SL KC - rear indicators
Leuchte 17TFL R BLK SRB3TFL R BLK SR KC3 - rear indicators
Leuchte 18BLK HLA60 - Left Rear Indicator
Leuchte 19BLK HRC31 - Right Rear Indicator
Leuchte 1BLK VRB20 - Indicator front right (headlight)
Leuchte 20BR LA71 - Left outer tail
Leuchte 21BR RC8 - Right out tail
Leuchte 22BR MA57 - 3rd Brake Light (centre)
Leuchte 23SL HLC10 - Left Inner Tail
Leuchte 24SL HRA65 - Tail light
Leuchte 25KZL HA59 - License plate light
Leuchte 26NSL LA72 - Rear fog
Leuchte 27NSL RC6 - Rear fog
Leuchte 28RFL LC11 - Reversing Light
Leuchte 29RFL RA64 - Reversing Light
Leuchte 2SL VLB10 - Daytime running lights left (headlights)
Leuchte 30FR LC72 - LED footwell lighting
Leuchte 31AMBL 1C61 - Ambient lighting front left (probable) (Xcellence ignore)
Leuchte 32AMBL 2C35 - Ambient lighting front right (probable) (Xcellence ignore)
Leuchte 33AMBL 3C36 - Surround back left lighting (probable) (Xcellence ignore)
Leuchte 34AMBL 4C37 - Surround back right lighting (probable) (Xcellence ignore)
Leuchte 3SL VRB21 - Daytime running lights right (headlights)
Leuchte 4TFL LB4 - Left and front DRL envelope
Leuchte 5TFL RB32 - DRL right and front marker
Leuchte 6ABL LC5 - Low beam front left (headlight)
Leuchte 7ABL RB1 - Low beam headlight right (headlights)
Leuchte 8FL LB39 - Light function cornering light left or parking ?
Leuchte 9FL RB2 - Light function cornering light right or parking ?
Ambient light units do not appear on the Golf Mk7s but Skoda have the first two of the four units marked up with AMBL. I'm assuming the surround back lights are probably the top back lights.
There are three other light adaptations below these:
Leuchtweitenregulierung - Lighting regulation
Leuchtenkonfiguration Sonstiges - Light configuration other
Leuchtenkonfiguration Aussenlich Heck Licht - Light configuration external rear lights
dzieki sprawdze
Re: OBDeleven
: 24 lis 2020, 14:29
autor: Edi
Witam
Panowie jestem nowy i zielony od miesiąca posiadam Ateca 1.5. Dzisiaj przeskanowałem odbeleven i pojawił się taki komunikat w module zestawów wskaźników i nie można go skasować. Błąd to Brak Nastaw podstawowych B201000 statyczny piorytet 2.
Numer oprogramowania: 5F0920750D Wersja oprogramowania: 8311 Numer sterownika: 5F0920750D Wersja sterownika: 305 Nazwa ODX: EV_DashBoardVDDMQBAB Wersja ODX: 009051 Długie kodowanie: 07A522126B80000800886A031001000000000000 Kody błędów: B201000 - Brak Nastaw podstawowych Statycznie. Może ktoś pomoże co zrobić dalej.
Re: OBDeleven
: 24 lis 2020, 15:08
autor: Eleonor
Mało danych .. coś grzebałeś , ustawiałeś , przestawiałeś ?
Auto Twoje od nowości ?
Masz gwarancje - Serwis
Re: OBDeleven
: 24 lis 2020, 18:56
autor: Edi
Nic nie było grzebane tylko kasowana inspekcja przyciskiem 00. Auto kupione miesiąc temu a jest z rocznika 2016/2017. Wiem tylko tyle że było włączane doświetlanie zakrętów.
Witam
Hi
Jak z nawiewem z obu stron leci podobna temperatura ?jesli tak to moze byc problem z obiegiem zewnetrznym tz klapy, silniczek , mozesz zresetowac : i przeskanowac sterownik obd11
